Toyota Land Cruiser 1990 FJ62, 3F, 182000kms
1990 TOYOTA LANDCRUISER
WARTHOG
The perfectly working A/C until recently, experiences
now weak air flow to cabin. The fan motor runs Ok. First I want to check air filter. Where is it?
Also A/C freezes and on long journeys must be switched off for some time. When restarted it is Ok and then freezes again. What can the cause?
Thanks
Oct 29, 2007 at 10:02 PM
  • 31,937 POSTS
Hi there,
You may already have solved this problem, but if not i will suggest some checks.
There is no cabin air filter in these Land Cruisers.
As to the performance of the A/C I would be checking the T.X valve (thermal expansion valve) if you can get the A/C pressures tested, this will aid your mechanic to pin point any fault.
Mark (mhpautos)
Dec 4, 2007 at 1:52 PM
