2001 Toyota Echo Starting Cold Engine
DAMCKENZIE
Engine Performance problem
2001 Toyota Echo 4 cyl Front Wheel Drive 148000 miles
If my echo has sat for a period of time (say 4 hours or more), and I try to start it, the engine dies immediately. It will continue to do this until I start the engine with the gas pedal slightly depressed. Once the engine has started, the car performs as always. Once the engine has warmed up, the car starts in its normal fashion (for example--running several errands). If, however, I go to work and let the car set until lunch time, I need to start the car with the gas pedal pushed in again. Any ideas? If you have an idea of what the problem is, could you give me an idea of the cost? Thanks.
Jan 29, 2009 at 7:02 AM
MMPRINCE4000
  • 8,548 POSTS
Most likely an idle air control valve intermittent malfunction or debris build up on throttle plate in throttle body.
Cost would depend on problem, If IAC it may need to be replaced, if throttle plate, the throttle body would need to be removed and cleaned.
Is your check engine light on?
Dec 8, 2009 at 10:19 AM
