2005 Toyota Echo wont start
41,000 MILES • 4 CYL • FWD • AUTOMATIC
LUIS15955
hello - car wont start - chaged fuel pump - sparkplugs
took injectors cleanning - efi fuse and relay ok - changed the front 02 sensor - did scan No codes -all ok
Nov 24, 2009 at 1:44 PM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Nov 24, 2009 at 3:43 PM
