sensors
RAYRATLIFF
I have a 1991 Toyota Cressida, straight 6, 110,000 miles. The engine idle will not come up to its proper 750RPM when engine is at operating temp. No Oxygen sensors have ever been changed. Which sensors could be causing the slow idle? I am selling this car and I want to make sure everything is in good working order before I sell to someone.
Thank You...[img:508352a783]http://www.2carpros.com/forum/automotive_pictures/54067_CressidaEngine_1.jpg[/img:508352a783]
Jan 15, 2007 at 9:39 AM
BRUCE HUNT
  • 3,754 POSTS
Is there good pressure on the clutch pedal? Miles on the clutch? This could be a throwout bearing and fork issue.
Nov 7, 2006 at 11:06 AM
SERVICE WRITER
  • 9,123 POSTS
ecu, cts,tps all are inputs, the isc valve would be my suspicion located on the air intake system.
Jan 15, 2007 at 10:15 AM
