Toyota Cressida
HOCKEYMAMA2007
I washed the engine on my just purchased 1989 Toyota Cressida and now it has absolutely NO power, it runs, but it can't go far because there is not enough power to go fast enough. HELP what is the problem, how can I fix it?
1989 Toyota Cressida 178000 Km 6cyl 24 valve
Sep 11, 2007 at 4:09 PM
  • 31,937 POSTS
Hi there,
Just washed the motor, take of the distributor cap and check for condensation, also clean the hi tension lead ends where they go into the cap, these will corrode and cause a problem. check that the spark plug terminals are also dry & clean.
Mark (mhpautos)
Sep 11, 2007 at 4:51 PM
