1997 Toyota Corolla Coolant Temp Range
MIJAZ26
what is the water temperature safe range at gauge aand if radiator fan turns off and on its auto sensor is ok.
Nov 15, 2007 at 7:56 PM
  • 75,988 POSTS
If the fan is coming On and Off the sensor is reporting the temperature to the computer and in turn energizing the fan relay which will operate the cooling fan/s
HOW HOT IS TOO HOT?
Most engines today are designed to operate within a "normal" temperature range of about 195 to 220 degrees F. A relatively constant operating temperature is absolutely essential for proper emissions control, good fuel economy and performance.
A 50/50 mixture of water and ethylene glycol antifreeze in the cooling system will boil at 225 degrees if the cap is open. But as long as the system is sealed and holds pressure, a radiator cap rated at 15 psi will increase the boiling temperature of a 50/50 coolant blend up to 265 degrees F. If the concentration of antifreeze to water is upped to 70/30 (the maximum recommended), the boiling temperature under 15 psi of pressure goes up to 276 degrees.
So does this mean a cooling system with a maximum concentration of antifreeze in the coolant (70%) can run as hot as 276 without boiling over? Theoretically yes -- but realistically no. The clearances in most of today's engines are much, much closer than those in engines built in the 1970s and early 1980s. Piston-to-cylinder clearances are much tighter to reduce blowby for lower emissions. Valve stem-to-guide clearances also are closer to reduce oil consumption and emissions, too. Plus, many engines today have aluminum heads with overhead cams. Such engines don't handle higher than normal temperatures well, and are very vulnerable to heat damage if the engine gets too hot.
Anytime temperatures climb beyond the normal range, the engine is running in the danger zone.
Nov 15, 2007 at 8:56 PM
Suggested Repair
A radiator fan that cycles on and off indicates the coolant temperature sensor is reporting to the computer and the fan relay is operating the fan. Normal engine temperature is about 195 to 220 F; temperatures above that range are in the danger zone and should be investigated.
Conversation Summary
The owner of a 1997 Toyota Corolla 1.6 XLi asked for the safe coolant temperature range and whether a radiator fan that turns on and off means the temperature sensor is OK. The expert said fan cycling shows the sensor is reporting to the computer and the fan relay is working. Normal operating temperature is about 195 to 220 F, and higher temperatures put the engine in the danger zone.
