That surely helped, thank you very much
[quote:ea3bb873c6="backyardmechanic"]One way you can tell if you have ABS without a manual is to check the dashboard for a ABS light. All cars equipped with ABS have a light to indicate when there is a problem with the system. Turn the key to the on postion to get all the indicator lights ( check engine light, oil, battery, etc ) If the car is equipped with Abs the light will come on at this time. Also look under the hood to see if the brake lines from the master cylinder go into a ABS control module. It looks like a box with brake lines and wires coming out of it. As far as adding anti-frezze you can add a 50/50 mix of anti- frezze to water. Add to the overflow tank to the proper mark.
Hope this helps Backyardmechanic :o[/quote:ea3bb873c6]
Dec 3, 2006 at 11:50 PM
