2004 Toyota Corolla Engine Clacking
AQUAMAN7827
Hi. I have a 2004, 4 cylinder Toyota Corolla LE Automatic, with about 67,000 miles. Recently i my oil indicatorstarted to flicker on and off, when i check the oil stick i was almost out. So i added a little bit of oil to the car, so that it kept me going, then a week later the light started to flicker again, this time the oil indicator light remained on, so again i added a little bit more oil, but the oil indicator light still remained on. Now my engine is making a clack clack clack clack noise everytime i push down on the excellerator, and my check engine light has gone on. When i pick up speed the noise leave, but when i stop and try to start up again that is when you hear the clack clack clack clack noise. Can you please help me out.
Nov 25, 2007 at 10:51 AM
  • 31,937 POSTS
Hi there,
You will have to get a code read to establish what has set a fault code. As for the noise, You better change the oil &filter, and have an oil pressure test done, you may have suffered internal damage due to lack of engine lubricant.
Mark (mhpautos)
Nov 25, 2007 at 3:25 PM
Suggested Repair
Read the check-engine fault codes, change the oil and filter, and have an oil-pressure test performed. Low oil may already have caused internal engine damage.
Conversation Summary
A 2004 Toyota Corolla with about 67,000 miles ran very low on oil; the oil light flickered, then stayed on after oil was added. The engine now clacks when accelerating from a stop, the noise fades at speed, and the check-engine light is on. The expert advised reading the fault code, changing the oil and filter, and testing oil pressure because lack of lubricant may have caused internal damage.
