1991 Toyota Corolla Cluster Lights Fix
LBRITTON
I need to replace the bulbs behind the intrument cluster in my 1991 corolla wagon. I can not figure out how to get to them once I get the dash off. Can you please provide directions as well as the buld type?
Thanks.
Feb 15, 2006 at 3:06 AM
FISHERMAN
  • 937 POSTS
i think those light bulbs are 1/4 turn push in type, turn 1/4 and pull out, you will be able to get them in the autoparts, just take a sample with you (some of them come with a color plastic cover wich you can "re-use" with a regular clear type).
Feb 16, 2006 at 1:26 AM
Suggested Repair
The instrument cluster bulbs are typically 1/4-turn push-in type. Turn each bulb a quarter turn and pull it out. Take a sample to an auto parts store to match the replacement. If a bulb has a colored plastic cover, reuse that cover with a clear replacement bulb.
Conversation Summary
The owner of a 1991 Toyota Corolla wagon wants to replace the instrument cluster bulbs and asks how to reach them after removing the dash, plus the bulb type. The expert says the bulbs are likely 1/4-turn push-in type that can be removed by turning a quarter turn and pulling out, and recommends matching a sample at an auto parts store. Colored plastic covers can be reused with clear replacement bulbs.
