When I changed the bearings (passenger side front) I damaged the ball joint boot. Instead of replacing the entire piece, I put a new boot around the old joint. I squeezed the lubricant out of a new one and put it around the old one. It was hard work but I managed to get a new boot around an older ball joint. :twisted: I know that it has been contaminated and should be replaced soon, but does the boot hold a pressure along with protecting the joint from debris?
Would this cause my car to pull when I accelerate moderately? I have read about torque steer, but it didnt drive this way before I replaced the bearings. I went through Napa to have them pressed, and I dont think that I damaged the Tranny or CV axle end when I removed/replaced CV axle. :arrow: Pulls to left when I accelerate and back right again when I let off.
