1993 Toyota Corolla Stalls When Stopping
ROCK2001WWF
  • 10 POSTS
My car stall when stop completely for a couple of seconds, I have changed fuel filter, coolant temp. sensor, and tune up stuffs.
I try to change to TCC solenoid, in my 1993 corolla 1.8 liter engine.
Where is it?
And how do i tell if the tcc solenoid is working?
Apr 24, 2006 at 12:21 PM
LOSONE
  • 1,616 POSTS
The TCC solonoid is the electronic device that causes the torque converter to lock-up and un lock when you are the drive over about 45.
Drive about 50, touch the brake lightly, if it is working the torgue converter will disengage and you will hear and engine rpm increase. After you hear the increase, it will shift back into lock up. The rpm change is about 250.
If the torgue converter will not unlock then it is a major stall condition as it will be a direct connection to the engine without a torgue converter. Good luck
Apr 24, 2006 at 12:33 PM
Suggested Repair
Road-test the TCC: drive about 50 mph and lightly touch the brake. If it is working, the torque converter should unlock, engine RPM should rise about 250, then lock up again. If it will not unlock, the direct coupling can cause a major stall.
Conversation Summary
The owner of a 1993 Toyota Corolla 1.8 says the car stalls for a couple of seconds when coming to a complete stop after replacing the fuel filter, coolant temperature sensor, and tune-up parts. They asked where the TCC solenoid is and how to tell if it works. The expert explained that it locks and unlocks the torque converter above about 45 mph and described a brake-tap road test looking for roughly a 250 RPM change; failure to unlock can cause a stall.
