1997 Toyota Corolla Brakes Overheat
MILLERLYTE2
I own a 1997 Toyota Corolla, 130000 miles. I had brake trouble, and the master cylinder was replaced in February 2007. The brakes were never right, and I took it back several times. The last time, the mechanic said he had no idea why the brakes weren't working properly. I would either have NO brakes (and use the emergency brake to stop), or have to accelerate to get down a hill (like they were stuck). Yesterday, my brakes caught on fire. Melted everything (even the hub caps!!). I had it towed to a different mechanic, and he said that he is very puzzled by all of this. He also said that he found some info saying that this has been a problem with my type of car...Any advice? Anyone ever hear of this happening???
May 9, 2007 at 11:21 AM
SERVICE WRITER
  • 9,123 POSTS
I have never run into this but certainly has my curiousity. Do you have anti-lock brakes as well?
How often has the brake fluid been flushed?
Was it the front brakes or rear brakes that caught fire?
Rear disc or drum brakes?
May 9, 2007 at 11:32 AM
MILLERLYTE2
[quote:4c7f38ecb8="Service Writer"]I have never run into this but certainly has my curiousity. Do you have anti-lock brakes as well? No
How often has the brake fluid been flushed? It was just done when the master cylinder was replaced in February. I have never had low brake fluid either.
Was it the front brakes or rear brakes that caught fire? front
Rear disc or drum brakes? not sure, but it was the front. [/quote:4c7f38ecb8]
May 9, 2007 at 11:44 AM
SERVICE WRITER
  • 9,123 POSTS
Fire....as in you SAW flames? both sides?
sorry for questions, just tryng to clarify.
May 9, 2007 at 12:01 PM
MILLERLYTE2
[quote:f96578dc88="Service Writer"]Fire....as in you SAW flames? both sides?
I did not see them, but with all the smoke, I grabbed my daughter and ran..lol...the mechanic that has looked at it today said that there had to have been one, everything is "melted" and the rotors are blue (means nothing to me, but everyone else seems to know what that means..).
np...I'm hoping that someone can help me!! This is going to cost a fortune to get everything replaced, and it would be nice to know how/why this happened, to make sure it doesn't happen again....[/quote:f96578dc88]
May 9, 2007 at 1:18 PM
SERVICE WRITER
  • 9,123 POSTS
Sounds like there was a hydrolic lock up casuing the calipers to stay in the on position. Before I would be suspicious of the master cylinder, I would be curious to know what brake problems led up to the Master being replaced. Perhaps it was mis-d iagnosed or bad master that was installed.
I would recommend checking the pushrod lenth at the master cylinder and shortening it if necessary and also check to make sure the slides are free and lubricated on the caliper, especially the top one.
May 9, 2007 at 9:52 PM
SERVICE WRITER
  • 9,123 POSTS
Soooo.....What happened?
May 11, 2007 at 1:08 PM
KAMO
  • 47 POSTS
From the sound of it I would say have your brake booster checked. Did the brake become very stiff before you had to accelerate down hill and such? Chance are if that was the case, your brakes didd not catch fire but built too much pressure that the booster could not release, resulting in your calipers locking. The brakes get stuck, it causes a lot of heat, and it starts smoking very violently if you drive on it.
Check the break booster.
May 16, 2007 at 8:39 AM
Suggested Repair
Inspect for hydraulic lockup that kept the front calipers applied. Check and shorten the master-cylinder pushrod if needed, confirm the caliper slides move freely and are lubricated (especially the top slide), and have the brake booster checked. Replace heat-damaged front brake parts before driving.
Conversation Summary
A 1997 Toyota Corolla with ongoing brake problems after a master-cylinder replacement had front brakes overheat, smoke, and melt nearby parts; the rotors turned blue. The owner reported either no brakes or brakes that seemed stuck. Experts suspected hydraulic lockup holding the calipers applied and recommended checking master-cylinder pushrod length, caliper slide freedom and lubrication, and the brake booster.
