1997 Toyota Corolla Rear Brake Noise
BMWOWNER
  • 19 POSTS
97 Totota Corolla, The noise only happens while applying the brakes and it comes from the right rear. I assume that it's not a wheel bearing or it would do it all the time. I have been told that it may be a brake shoe slipping?
May 29, 2006 at 8:48 AM
LOSONE
  • 1,616 POSTS
Don't hesitate! Pull the rear wheel and look at the brakes before you do some real damge and loose your brakes all the way. I suspect a broken brake spring
May 30, 2006 at 10:44 AM
BMWOWNER
  • 19 POSTS
[quote:fe4c286379="losone"]Don't hesitate! Pull the rear wheel and look at the brakes before you do some real damge and loose your brakes all the way. I suspect a broken brake spring[/quote:fe4c286379]
Thanks. I'll check that. :D
May 31, 2006 at 8:16 AM
Suggested Repair
Remove the right rear wheel and inspect the brakes promptly. Check for a broken brake spring or a slipping brake shoe before the brakes are damaged or fail.
Conversation Summary
The owner of a 1997 Toyota Corolla reported a noise from the right rear only while braking and wondered whether a brake shoe was slipping. An expert advised inspecting the rear brakes immediately and suspected a broken brake spring, warning that delaying could lead to brake damage or loss of braking. The owner agreed to check it.
