1998 Toyota Corolla Abnormal sound at 30 kmph
SHRINIVEL
  • 1998 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • MANUAL
  • 280,000 MILES
last month I found some sound in front wheel then I repaced front wheel bearing and brake shoe then there was no sound. Now Again I abserved some abnormal sound in the front side at the speed of 30kmph but higher and lower than 30 no abnormality. Could you please advise me what could be the reason?
Thursday, May 14th, 2009 AT 2:25 PM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and push/pull both horizontally and vertically, if any movement then possible wheel bearing, ball joint, tie rod, control arm bushing.
Check CV boots for any signs of leakage or cuts/rips in rubber boot.
Check tires for abnormal wear.
If you perform the above and fine no movement, then look for loose exhaust components (shields), also move fron wheels from front to rear (LF to LR, RF to RR), if noise move with them, then tire is problem.
Friday, May 15th, 2009 AT 8:03 AM
