My car a Toyota Corolla drains power from somewhere in the electrical system.I 'v checked the battery,and from that side everything seems to be okay. but during the night, when the car is off and temperature outside are low(on the freezing) the lights of the car get turn on themselves, draining the battery.Also sometimes, when i want to shut off the engine the dashboard panel it doesn't. so the car is off but the ,lights are still on, even though i turned them off.And this happens mostly when is below 30 degree outside.the only way that i can turn off the lights is to turn on the left signal.
Also, even when the car is off, if I touch the signal stick it makes something that seem as electrical shock.
i v checked with mechanics but nobody seems to know why is this happens.
thanks in advance...
Dec 12, 2008 at 11:59 PM
