2002 Toyota Corolla spark plug performance
153,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBSTOY
  • 14 POSTS
Hi Car carpros;
I would like to change plugs on my corrolla, and would like to use aftermarket plug to save money; can you recommend a good plug with autolite or boosch; i have been using toyota's iridum plugs which are supposed to last 90 to 100,00 miles but are expensive; that have white deposits with some black carbon buidup. Rob
Feb 8, 2009 at 6:07 AM
MMPRINCE4000
  • 8,548 POSTS
Use NGK iridium, stay away from Autolite, if you must, use Bosch platinum (single ground) not the +2 or +4.
But NGK is a better plug. Use a dab of antisieze on plug threads when installing.
Look at chart below to see what your plugs look like:
https://www.2carpros.com/how_to/how_to_change_my_spark_plugs.htm
You can buy NGK plugs at most autoparts stores, significantly cheaper than from Toyota.
Feb 8, 2009 at 10:46 PM
