Recheck spark plug installation, make sure they are tight, and make sure you used the correct plug, either Denso or NGK iridium.
Check connections to coil packs. Make sure you did not get one out of order.
SPONSORED LINKS
Tuesday, June 9th, 2009 AT 7:28 AM
