The radio and clock went off where fuse box is?
SCAMPBELL33023
  • 2000 TOYOTA COROLLA
  • 4 CYL
  • 96,000 MILES
There is no power to my radio. Where is the radio fuse located?
Monday, October 22nd, 2018 AT 8:36 PM (Merged)
MMPRINCE4000
  • 8,548 POSTS
Should be kick panel on drivers side by left foot or open door and look at end side of dash.
CHAVALIRAGHU
  • 2002 TOYOTA COROLLA
  • 4 CYL
  • FWD
Location of fusible link in corolla 2002
CARADIODOC
  • 33,916 POSTS
For which circuit? Fuses are in a fuse box under the hood. Fuse "links" used to be wires of a smaller diameter soldered into the wiring harness and had insulation that wouldn't burn. Now fuse links are large fuses that plug in. Often the very large generator fuse is bolted in.
MISTIKO2012
I just bought a 2002 toyota corolla radiator cooling fan dont turn on but I know they worked because I run a cable from the battery terminals and they turn on. I replaced the sensor and some relays and still dont work and the car overheats in a period of time while running because the fans are not getting the signal to turn on. The engine main relay under the hood is missing could that be the problem? And if yes where can I get it I just cant find it.
Saturday, April 20th, 2019 AT 7:08 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,363 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Monday, April 22nd, 2019 AT 3:38 PM
