I was wondering if I could have some help recognizing what might be going on. After you drive the car for like 10 min. You start hearing a knocking noise, but it is by where the timing chain would be. Is this a common problem for when the timing is off or anything? Appreciate your help.
SPONSORED LINKS
Tuesday, October 19th, 2010 AT 3:36 PM
MMPRINCE4000
MECHANIC
You would have to check the chain, by removing the cover, there may be a broken guide or cog in gear.
You can remove the valve cover and look down at chain and gears with light.
