Knock when acelerating
120,000 MILES
MARIOC68
  • 120 POSTS
My car makes a knocking noise when accelerating. I have tried STP octane booster, but did not solve the problem.
Jul 9, 2016 at 10:20 AM
HMAC300
  • 48,601 POSTS
have a local mechanic take a look at this as it may be an internal engine problem requiring teardown due to something being seriously wrong. make sure you oil is full.
Jul 10, 2016 at 1:52 AM
MARIOC68
  • 120 POSTS
Hello.
Take a compression test on the engine, these are the results:
Cilinder 1: 220 psi
Cilinder 2: 216 psi
Cilinder 3: 220 psi
Cilinder 4: 220 psi
The nominal pressure for this motor (5A-FE) according to the workshop manual is 14,0 kg / cm2=200 psi And the minimum of 10, 0 kg= 142 psi.
Could this 20 psi difference cause the spark knock?
May 1, 2017 at 1:21 AM
HMAC300
  • 48,601 POSTS
not really compression numbers are good but timing cold be advanced to far as I dont' know where it is sitting whether it is where it's supposed to be or not. also has anything been done to pistons like putting higher compression pistons in or shaving the head more than .030" as that can cause it to especially if you are running lower octane fuel.
May 1, 2017 at 2:35 AM
MARIOC68
  • 120 POSTS
I will try by adding octane booster.
May 1, 2017 at 2:41 AM
HMAC300
  • 48,601 POSTS
if you are using 87octane then just try going to 89 or 93 insead of that junk there are only a few on the market that work.
May 1, 2017 at 2:48 AM
MARIOC68
  • 120 POSTS
There is a probability that the combustion chamber must have char.
May 1, 2017 at 3:27 AM
HMAC300
  • 48,601 POSTS
I f you think that is the problem gm/ford dealers sell a top engine cleaner to put in engine to get rid of that.
May 1, 2017 at 5:07 AM
