2000 Toyota Corolla Knocking at every startup
HEMANKAPS
  • 2000 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 118,400 MILES
I have a 2000 toyota corolla LE 4 cyl. There is a knocking sound whenever the vehicle is started and run for a couple miles. This knocking goes away eventually.
But when the engine is restarted, even if it is warm/hot, the knocking again comes for a few miles.
How to fix this problem? Any pointer or help is appreciated. Atleast throw some light on the problem area.
Thanks
Himanshu
Monday, October 18th, 2010 AT 1:33 AM
Sounds like a lifter leakdown problem -when it pumps up the noise goes away
Monday, October 18th, 2010 AT 1:46 AM
MMPRINCE4000
  • 8,548 POSTS
If it was a main/rod bearing, it would not go away.
Possible lifter, but I would also check the accy. Drive, like the tensioner.
On cold engine, remove belt(s) and start engine for a minute, if no noise, then a belt driven accy. Is problem.
Monday, October 18th, 2010 AT 8:34 AM
