In the last 4 months the bolt holding the tensioner pulley onto the engine block has broken 3 times right where the threads start. I have drilled out the remaining piece each time and had a new bolt installed. I have even replaced the pulley assembly and a few weeks later the bolt broke again.
What might be the root cause of the bolt failure?
Not sure if it would help but just prior to each failure of the bolt I can hear the belt squeal slightly a few hours before it breaks.
Nov 3, 2010 at 8:55 PM
