1999 Toyota Corolla starter
JERRYLAN5566
  • 1999 TOYOTA COROLLA
Electrical problem
1999 Toyota Corolla 4 cyl Front Wheel Drive Automatic
how is starter removed
Wednesday, April 15th, 2009 AT 10:36 PM
EUGENE123
  • 273 POSTS
2. Remove or disconnect the following:
Radiator upper support seal
Air cleaner
Engine under covers
Starter wiring
Starter
3. Installation is the reverse of removal. Torque the bolts to 28 ft. Lbs. (37 Nm). Note that the bolts are 2 different lengths.
Battery and tray. On models equipped with an air bag, work must NOT be started until at least 90 seconds have passed from the time that both the ignition switch is turned to the LOCK position and the negative cable is disconnected from the battery.
Coolant reservoir
Reservoir hose from the radiator
Right side under cover
Wiring clamp
Wiring from the starter
Starter
To install:
1. Install or connect the following:
Starter
Starter wiring and nut
Starter connector and wire clamp
Right side engine cover
Radiator reservoir and hose
Battery and tray
2. Check the cooling system and top off if necessary.
1. Before servicing the vehicle, refer to the Precautions section.
Negative battery cable. On models equipped with an air bag, work must NOT be started until at least 90 seconds have passed from the time that both the ignition switch is turned to the LOCK position and the negative cable is disconnected from the battery
Engine under covers
Wiring from the starter terminals
Starter mounting bolts
Starter
To install:
Starter
Starter wiring
Engine under covers
Front engine undercover
Starter wiring harness connectors
Starter motor
To install:
Starter motor. Tighten the bolts to 28 ft. Lbs. (37 Nm).
Wednesday, April 15th, 2009 AT 10:42 PM
