1991 Toyota Corolla Starter
RICK R
  • 1991 TOYOTA COROLLA
  • 4 CYL
  • 11,900 MILES
I have an intermittent problem with my car. Sometimes after I've been driving it for a while and stop and turn off the car, it won't start when I get back into it. When I turn the key nothing happens. No click or anything. I've had the battery tested and it's fine. I've heard that if the starter gets hot it won't work. How do I know if it's my starter?
Friday, September 5th, 2008 AT 8:02 AM
2CARPRO JACK
  • 11,533 POSTS
Check for 12 volts a the small wire on the starter with key in crank position, if it has it, the starter is bad, if not get back to me and we will see where it is stopping
Friday, September 5th, 2008 AT 8:04 AM
RICK R
Thanks for the reply. I bought this car in July and I've never owned a Toyota before. Where is the starter located?
Friday, September 5th, 2008 AT 8:16 AM
MMPRINCE4000
  • 8,548 POSTS
It is on the firewall side under the intake manifold next to the trans. Bellhousing.
Remove the passengers side tire and put the front end on jackstands. Then the stone shields. Two bolts hold it in place, one faces passengers side, one drivers side.
Another option is to remove starter (disconnect negative battery cable) and have sarter tested at most auto parts stores.
Saturday, September 6th, 2008 AT 6:24 AM
