Engine Mechanical problem
1998 Toyota Corolla 4 cyl Front Wheel Drive Automatic 98.000 miles
starter stays ingaged while car is running. When shut off with key off have to disconnect battery to stop all
Friday, February 6th, 2009 AT 8:36 PM
BLUELIGHTNIN6
MECHANIC
Hello
Thanks for the donation.
Suspect faulty starter solenoid or ignition switch. Remove starter from vehicle and have it tested at a local part store. Most will do this test for free of charge. If starter and solenoid test OK, replace ignition switch. If you need further assistance just let me know.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Friday, February 6th, 2009 AT 8:37 PM
STEVIEB4464
MEMBER
I took the starter off had it checked at autozone they said it was fine. Went on my own decsion to replace it and that was the problem
thanks
steve
P.S. I have never had good luck with them testing batteries, altanators or starters
