1999 Toyota Corolla
BENJIBOB25
  • 1999 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 130,000 MILES
The car is throwing 2 codes. Random Multiple Misfire and Cylinder 4 Misfire. It surges very badly and you have to go through the gears to get it to go (automatic tranny). I think it is either bad ignition coils or cam, crank sensor or the ecm.
Monday, October 20th, 2008 AT 7:07 PM
  • 31,937 POSTS
Hi there,
I would be investigating the ignition system first, if it was a cam sensor it would give a different code as well as the misfire and cams don't give much of a problem at all, I would be looking into the ignition first.
Mark (mhpautos)
Monday, October 20th, 2008 AT 7:25 PM
