1998 Toyota Corolla Fan switch only works in highest speed
1998 TOYOTA COROLLA
100,700 MILES • 4 CYL • FWD • AUTOMATIC
DERWOODDERWOOD
My '98 Toyota Corolla fan switch has 4 levels, from low to high. The fan will only be on when I turn to the highest speed, not the other three levels from low. What would be the problem? Do I need to replace an switch, or just the relay problem?
Sep 5, 2008 at 9:20 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:925d1f0312="derwoodderwood"]Air Conditioning problem
1998 Toyota Corolla 4 cyl Front Wheel Drive Automatic 100700 miles
My '98 Toyota Corolla fan switch has 4 levels, from low to high. The fan will only be on when I turn to the highest speed, not the other three levels from low. What would be the problem? Do I need to replace an switch, or just the relay problem?[/quote:925d1f0312]
Sounds like your Blower Motor Resistor. It is located below right side of dash, in heater a/c housing.
Sep 5, 2008 at 9:46 AM
