1997 Toyota Corolla Outside smoke comes to inside
INDIKA911
  • 1997 TOYOTA COROLLA
Air Conditioning problem
1997 Toyota Corolla Engine Size unknown Front Wheel Drive Automatic 125000 miles
Smoke or smell from outside comes to the inside of the car. Are there any holes or windows that comes outside air to inside other than fresh air window (I have double checked the fresh air window, it closed perfectly but smoke comes in)
Monday, January 7th, 2008 AT 3:10 AM
  • 31,937 POSTS
Hi there,
You have the option of recirculated air or outside air on your heater controls, if you controller is on inside air, I think it is a picture of the car with arrow circling the out side vent should be closed, if not you will still have outside air, entering the car and this can carry smells from the out side into the cabin, you mechanic will be able to check if the flap is closed fully and if it is working as it should.
Mark (mhpautos)
Monday, January 7th, 2008 AT 7:03 AM
Related Air Conditioner Not Working Content
