1997 Toyota Corolla electrical problems
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
PMP
  • 177 POSTS
i have a few problems. first when i hold up all the power window switches the lights dim a little what could this be? also my left blinker is blinking real fast and ive checked all the bulbs on that side and changed a few and its still blinking anything to check? Ty
Apr 10, 2009 at 2:00 PM
  • 31,937 POSTS
Hi there,
I would be thinking that the window switch or the motor is failing and you are having a current draw issue, i would un plug the motor and see if the switch alone is acting up, (place a test light in place of the motor to make a circuit, also is the motor slower that the others?, with the indicators, if all the globes are ok, change the flasher can.
Mark (mhpautos)
Apr 10, 2009 at 2:29 PM
PMP
  • 177 POSTS
whats the flasher can and how you check it?
Apr 10, 2009 at 2:31 PM
  • 31,937 POSTS
Hi there,
The flasher can is the control device that gives the constant flash rate for the indicators, i will locate a pic and location for you and post back.
mark (mhpautos)
Apr 10, 2009 at 4:23 PM
