1997 Toyota Corolla No Crank After Jump
MRDAVIS1970
The jumper cables were placed incorrectly when a friend needed a jump. 3 days later my car acts like it wants to crank but doesn't. My radio and lights still come on. All fuses were checked and they're still good. If the computer was fried then nothing would come on. Is that true or not? It's got roughly about 132,000 miles and it's a 4 cylinder.
Aug 19, 2007 at 6:51 AM
  • 31,937 POSTS
Hi there,
If you damaged the ECU the problem would be when you spiked the electrical system, (normally) I would think that you may have shorted out the alternator and the battery has taken a few days to discharge. Have the charge system tested and also have a falt code read on the ECU done to be safe.
Good luck , Mark (mhpautos)
Aug 19, 2007 at 1:37 PM
Suggested Repair
Have the charging system and battery tested, since a reverse jump may have shorted the alternator and allowed the battery to discharge. Also have the ECU scanned for fault codes.
Conversation Summary
A 1997 Toyota Corolla with about 132,000 miles acts like it wants to crank but does not, three days after jumper cables were connected incorrectly. The radio and lights still work, and the fuses check good. The owner asked whether a fried computer would leave nothing powered. The expert said ECU damage would usually appear when the electrical system was spiked, and suspected a shorted alternator with a slowly discharged battery. They recommended testing the charging system and reading ECU fault codes.
