Air Conditioner not working
Let me know when you do-check it
Tuesday, April 30th, 2019 AT 1:16 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
Go to the fuse box under the hood and see if the ac fuse is blown remove the fuse and look thru it you can see thru it and see if its blown. To see if there is pressure in the system you need ac gauges. Let me know if the fuse is good.
WAQAS27
  • 11 POSTS
Ok, I will check it tomorrow, will tell u after 7 hours. Thank you for your kind valuable support.
PEPLAR
Hi, the fuse is good, does not look blown and its fine when I tested it.
WAQAS27
  • 11 POSTS
I have checked the A/C fuse(10A) and A/C Circuit Breaker fuse(30A) in passenger side kick panel, also checked the magnetic clutch relay in engine compartment fuse box. ALL are OK !
SATURNTECH9
  • 30,869 POSTS
Alright now you have to check the pressures in the ac system.
Lets connect the black wire and see what happens-but 1st check for power on the black wire coming from the AC Amp-before hook-up to the ignitor-Your 1st pic-can you buff it up a bit can't read it
WAQAS27
  • 11 POSTS
Yes, the A/C is now working as I connected the wire to new distributor's -ve terminal (black wire of new distributor. This wire was previously connected to old distributors coil -ve. The Problem is solved, Thanks a lot for your valuable support !
Your welcome
