Valve clearance please?
PHILLSOP
Engine Mechanical problem four cylinder manual 82,000.
What is the intake and exhaust valve clearance for this engine??
Jun 28, 2008 at 12:58 AM
MMPRINCE4000
  • 8,548 POSTS
Intake is .006-.010 and exhaust is .008-.012. Clearance is on a cold engine.
This engine uses shims to adjust valve clearance and you need a special tool to remove the shims and install new ones. You can get new shims from Toyota.
If the camshaft lobes are worn then the camshafts must be replaced.
Jun 29, 2008 at 12:31 AM
PHILLSOP
This is one of those from Japan. Four cylinder two wheel drive manual wagon.
It comes with twelve valve 2E carburetor engine.
Please tell be the timing and the valve clearance.
Jun 29, 2008 at 8:33 PM
MMPRINCE4000
  • 8,548 POSTS
Does it have rocker arms? It may be the 4ALC instead of the 4AFE.
Jun 30, 2008 at 12:31 AM
PHILLSOP
Yes. This engine carries rocker arms. It is a 1198 cc carburetor engine.
Jun 30, 2008 at 6:09 AM
KHLOW2008
  • 41,812 POSTS
Hi phillsop,
Valve clearance is .008 for both intake and exhaust, hot adjust.
Timing = 5/800 rpm.
Jul 2, 2008 at 4:59 AM
PHILLSOP
I wish to thank all of you very much for your help.
Keep the fire burning.
Regards,
Phillsop
Jul 2, 2008 at 10:31 AM
FRITTZDAHAN
Hi everyone, im realy confused becoz some guys told me larger valve clearance.. Intake .02 while exhaust is .03.. For corolla e90 model
Jul 21, 2017 at 10:41 PM
  • 55,588 POSTS
I am showing .008 for both.
Cheers, Ken
Jul 24, 2017 at 4:39 AM
