1985 Toyota Corolla Valve clearance
200,000 MILES • 4 CYL • FWD • AUTOMATIC
PETERDI
What should be the valve clearance for this model toyota Corrola?
Thanks to Mark for answering my previous post, VERY much appreciated.
kind regards to all.
P.F
Nov 10, 2008 at 6:02 PM
  • 31,937 POSTS
Hi there,
carby engine, inlet .20mm exh .30mm
EFI engine inlet .20mm exh .25mm
Both engines should be at normal operating temp to set clearances.
mark (mhpautos)
Nov 10, 2008 at 6:49 PM
PETERDI
Thank you Mark, your help is greatly appreciated.
Kind regards.
Peter
Nov 10, 2008 at 7:19 PM
  • 31,937 POSTS
Good luck and i hope the re build goes well, thank you for using 2carpros.
Mark (mhpautos)
Nov 10, 2008 at 7:26 PM
