2002 Toyota Corolla Request for VVT-i
2002 TOYOTA COROLLA
170,351 MILES • 4 CYL • FWD • AUTOMATIC
SHOHIDUL ISLAM
How dose work VVT-i system. Also coming noise from tapped cover. please discuase about VVT-i. How can adjust valve clearance.
Apr 30, 2010 at 11:32 PM
  • 31,937 POSTS
VVTL-i (Variable Valve Timing and Lift intelligent system) is a version that can alter valve lift (and duration) as well as valve timing. In the case of the 16 valve 2ZZ-GE, the engine has 2 camshafts, one operating intake valves and one operating exhaust valves. Each camshaft has two lobes per cylinder, one low rpm lobe and one high rpm, high lift, long duration lobe. Each cylinder has two intake valves and two exhaust valves. Each set of two valves are controlled by one rocker arm, which is operated by the camshaft. Each rocker arm has a slipper follower mounted to the rocker arm with a spring, allowing the slipper follower to move up and down with the high lobe without affecting the rocker arm. When the engine is operating below 6000-7000 rpm (dependent on year, car, and ECU installed), the low lobe is operating the rocker arm and thus the valves. When the engine is operating above the lift engagement point, the ECU activates an oil pressure switch which pushes a sliding pin under the slipper follower on each rocker arm. This in effect, switches to the high lobe causing high lift and longer duration.
The system was first used in 1999 Toyota Celica SS-II with 2ZZ-GE. Toyota has now ceased production of its VVTL-i engines for most markets, because the engine does not meet Euro IV specifications for emissions. As a result, this engine has been discontinued on some Toyota models, including that of the Corolla T-Sport (Europe), Corolla Sportivo (Australia), Celica, Corolla XRS, Toyota Matrix XRS, and the Pontiac Vibe GT, all of which had the 2ZZ-GE engine fitted. The Lotus Elise continues to offer the 2ZZ-GE and the 1ZZ-FE engine, while the Exige offers the engine with a supercharger.
In 1998, Dual VVT-i which adjusts timing on both intake and exhaust camshafts was first introduced on the RS200 Altezza's 3S-GE engine.
Dual VVT-i is also found in Toyota's new generation V6 engine, the 3.5-liter 2GR-FE first appearing on the 2005 Avalon. This engine can now be found on numerous Toyota and Lexus models. By adjusting the valve timing, engine start and stop occurs almost unnoticeably at minimum compression. In addition fast heating of the catalytic converter to its light-off temperature is possible thereby reducing hydrocarbon emissions considerably.
Toyota's UR engine V8 also uses this technology. Dual VVT-i was later introduced to Toyota's latest small 4-cylinder ZR engines found in compact vehicles such as the new Toyota Corolla and Scion xD and in larger 4-cylinder AR engines found in the Camry and RAV4
the valve clearance is set with solid shims, these can be replaced but there are a set of shim charts and removal tools required.
Mark (mhpautos)
May 1, 2010 at 8:51 AM
