1990 Toyota Corolla sensor
MUNAVERKHAN
Engine Mechanical problem
1990 Toyota Corolla 4 cyl Front Wheel Drive Automatic
how many they are and how does they work?
Dec 8, 2008 at 7:32 PM
  • 31,937 POSTS
Hi there,
There are a number of sensors on the engine, speed, cam & crank angle, knock, temp, mas air flow, pressure and the list goes on, they all work in a variety of ways some are heat sensitive, some pressure sensitive some position indicator (TPI) there are to many to be describing here, if you do a web search you should find all your answers.
mark (mhpautos)
Dec 8, 2008 at 7:38 PM
