1990 Toyota Corolla Repairing Harmonic Balancer
1990 TOYOTA COROLLA
25,000 MILES • 4 CYL • FWD • AUTOMATIC
LOOKSTARE
How do I remove and replace the harmonic balancer in a 1990 Corolla? What tools do I need? Can you show me a diagram?
Aug 13, 2008 at 1:45 AM
MMPRINCE4000
  • 8,548 POSTS
Remove the balancer bolt, without an impact wrench you should loosen it before taking the belts off. If you have trouble with the balancer bolt, rent or borrow an electric impact wrench.
The balancer is not pressed on, it should slide off, but there may be some rust on the crank, so use some PB Blaster to disolve the rust.
Aug 14, 2008 at 12:05 AM
