Blue smoke is motor oil being burned in combustion chamber.
If this occurs during startup and then goes away or mostly goes away, it is the valve stem seals, which would need to be replaced. This can be done without removing head, but requires a special tool set.
If it occurs all the time, it could still be valve stem seals, or piston rings. A compression test will tell you if rings are bad.
SPONSORED LINKS
Saturday, December 12th, 2009 AT 8:05 AM
