1990 Toyota Corolla Car sputtering and stalling
XTEMPORE
  • 1990 TOYOTA COROLLA
  • 4 CYL
  • MANUAL
  • 145,000 MILES
On Friday I drove the car. It was raining heavily. Car was running fine, but almost out of fuel. I stopped at a service station and filled up.
About 5 kilometres later the car started to sputter and almost stall. For the rest of the drive home it would sputter every so often, especially losing power when accelerating.
I don't know much about cars, but thought maybe it had got a little water in the tank when I was filling it up, or possibly because the tank ran very low it sucked up some junk into the fuel line.
I had hoped it might just clear itself out. I took it for a run around the block yesterday, and it seemed about the same.
Today I had a lot of trouble starting it, and if took my foot off the accelerator it stalled every time.
Any thoughts about what the problem might be? And possible remedies?
Money's pretty tight at the moment, so I'd rather not have the expense of taking it to a mechanic unless I really have to.
Monday, December 15th, 2008 AT 8:39 PM
DSPLC
  • 220 POSTS
There are lots of causes for this problem. Here are few which miay or may not answer your problem. Maybe water got inside the distributor. Try drying up the inside of the distributor cap. Another cause might be the spark plug wires. If little water got in the fuel tank, I saw a gas additive at the auto parts supply that clears water in the fuel tank.
Tuesday, December 16th, 2008 AT 2:00 AM
