Drive Train Axles Bearings problem
1989 Toyota Corolla 4 cyl Two Wheel Drive Automatic
how do you get the axle out of the transmission we tried prying
Monday, July 14th, 2008 AT 6:53 PM
MASTERTECHTIM
MECHANIC
Pry harder. Get bigger prybar. It will come out. For some reason this model sometimes is very very hard to get the axles out. I find the best way is to apply pressure with pry bar and have someone hit the axle with a hammer to jar it free. There is only a small ring that holds it in. If you have access to a air hammer use that while prying
