1999 Toyota Corolla Axle
DBBDSUN
Drive Train Axles Bearings problem
1999 Toyota Corolla 4 cyl Front Wheel Drive Automatic
Hi wanted to know how long can i probally drive if axle on front right side is making noise that seems to be axle/bearings.Now this noise can be there today loud an not there at all the next even with same turning,since i live on curve road.
Thank you for your time
sincerley
Debbie
Oct 23, 2008 at 2:36 AM
MMPRINCE4000
  • 8,548 POSTS
You should replace it ASAP. If it were to sieze, it could cause an accident and damage the trans.
Generally the CV boot gets torn/ripped and the grease leaks out. This leaves metal to metal contact, which will overheat and eventually sieze.
Oct 24, 2008 at 1:40 AM
