HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Drivetrain
Differential
Axle
Bearing
SPONSORED LINKS
1989 Toyota Corolla installing drive axles
KENNYRDNEK
MEMBER
1989 TOYOTA COROLLA
Drive Train Axles Bearings problem
1989 Toyota Corolla 4 cyl Front Wheel Drive 133824 miles
installed new axles a month ago and appears driver side has come out how do u install and make sure its lock in
Monday, December 8th, 2008 AT 4:47 PM
MMPRINCE4000
MECHANIC
There is a small "C" clip that retains the tripod to the trans.
It may have come off or is deformed. Remove axle and check "C" clip.
Once you snap the axle in it should not move out, if it does, it is not in correctly.
SPONSORED LINKS
Tuesday, December 9th, 2008 AT 9:00 AM
Please
login
or
register
to post a reply.
Related Differential Axle Bearing Content
1989 Toyota Corolla Cant Get Axle Out
Drive Train Axles Bearings Problem 1989 Toyota Corolla 4 Cyl Two Wheel Drive Automatic How Do You Get The Axle Out Of The...
Asked by
geemjr
1 ANSWER
1989
TOYOTA COROLLA
GUIDE
Axle Bearing and Seal Replacement Rear 3/4 and 1 ton
This guide is created to show you how to replace an axle seal and bearing on a 3/4 and 1 ton rear axle. Most trucks and SUV's use the same style of Dana rear end so this...
Very Loud Noise Coming From Left Axle Area
Very Loud Thrashing Noise Coming From Left Axle Area. Very Noticeable At 2800 Rpm's Or Higher. I Jacked It Up To Find Which Side It Was...
Asked by
bobbaker
1 ANSWER
1 IMAGE
2006
TOYOTA COROLLA
1999 Toyota Corolla Axle
Drive Train Axles Bearings Problem 1999 Toyota Corolla 4 Cyl Front Wheel Drive Automatic Hi Wanted To Know How Long Can I Probally...
Asked by
dbbdsun
1 ANSWER
1999
TOYOTA COROLLA
1999 Toyota Corolla Weird Cracking Noise
Just Did The Front 2 Axels/cv On My Corolla And Bearins On The Right Side. Now My Car Is Making A Weird Cracking/popping Noise When I Drive...
Asked by
texasb22
1 ANSWER
1999
TOYOTA COROLLA
1989 Toyota Corolla Removing Axle
1989 Toyota Corolla 4 Cyl Two Wheel Drive Manual My Son Is Putting A New Clutch In My Corolla Gts. He's Having Trouble Getting The...
Asked by
LadyT98661
1 ANSWER
1989
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Rear Axle Seal Replacement
Axle Bearing and Rear Seal Replacement Rear 1/2 ton
Online car repair manuals
