Nope, they "pop" out. The best tool to use is a slide hammer with an CV axle attachment.
You can get a long heavy screwdriver and put on slot on tripod side, (from opposite side) use hammer and whack it a few times.
Some cars have axles that are bolted to trans, but most use a "C" clip at end of axle that compresses as it is going in then expands into slot in trans.
They can sometimes be a pain to get out.
Go to autoparts store and look at replacement axle, and you will see the small "C" clip that holds axle in.
SPONSORED LINKS
Saturday, February 6th, 2010 AT 7:47 AM
