1993 Toyota Celica Delayed Throttle
THE_HYDROXIDE_CHILD
  • 82 POSTS
i have a 1993 toyota celica gt with a 2.2L engine... the other day my water pump started throwing water everywhere.... i would have changed it but it calls for the timing belt to be removed and stuff.... i put it in the shop and they replaced the whole timing kit and had to pull the cams to replace the seals because they were leaking... now anytime u rapidly press on the gas pedal the car acts like it forgets what its suppose to do then says ohh yea.. vroom!!... but its like a slow rev... its like its all been delayed.... could this be the timing is off or would that not matter? pelase help if possible
Sep 26, 2007 at 2:14 PM
  • 31,937 POSTS
Hi there,
If this fault only started after the pump and belt was changed i would be checking the valve timing. From memory there should be two lines the aligine at 3 & 9 O'clock on the cams' thia is with the engine at T.D.C. No1. This is on the inside of the gears also it is important the the pe loader on the inlet cam is set correctly. I will check a toyota engine manual tomorow and re post if there is anything else or the marks are in a different position. There is one other thing that can cause this and i came across it the other day, the Exhaust was blocked via a faulty Cat converter, just something else to think about.
Mark (mhpautos)
Sep 27, 2007 at 12:48 AM
Suggested Repair
Because the delay started after the timing kit and cam seal work, recheck valve timing with the engine at TDC on No. 1, including the cam gear marks and inlet cam preloader. Also consider a restricted catalytic converter as another possible cause of the delayed response.
Conversation Summary
A 1993 Toyota Celica GT with a 2.2L engine developed delayed throttle response after a shop replaced the timing kit and cam seals following a leaking water pump. The owner asked whether the timing could be off. The expert recommended verifying cam timing marks and the inlet cam preloader, and also suggested checking for a clogged catalytic converter.
