Toyota Celica Battery Corrosion Test
FARSCAPE
you bring the battery into a shop to check to see if its time to replace, they place the meter on it and its time for a new one, my quesition is though they are putting the click onto the battery cable with acid all on the inside and around the terminal, they clain its no good and it doesnt matter the meter can detact through it! is this TRUE?
Oct 30, 2007 at 4:47 AM
  • 31,937 POSTS
Hi there,
It would make good seance to have clean test equipment and clean the terminals, but the load meter will have sharp teeth that make a good contact with the soft lead terminal post, so if they are testing properly i would believe them. Also if the battery is around 3 years old have a look at the electrolyte in the battery (don't touch it or get it on your clothes) if it looks cloudy it's a fair bet that the battery is due for replacement.
Mark (mhpautos)
Oct 30, 2007 at 5:38 PM
Suggested Repair
A proper load test can still be trusted if the tester jaws bite into the soft lead posts, though cleaning the terminals first is better. If the battery is about three years old and the electrolyte looks cloudy, replace it. Do not touch the electrolyte.
Conversation Summary
The owner asked whether a shop can correctly condemn a Toyota Celica battery when acid and corrosion cover the cable and terminal. The expert said clean equipment and terminals are preferable, but a load meter's sharp teeth usually make good contact with the soft lead post, so a proper test can be believed. Cloudy electrolyte in a roughly three-year-old battery also indicates replacement.
