1990 Toyota Celica Charge Light On
TEMMUCHIN
I was driving my car (1990 Toyaota celica GT liftback manual 2.2L) the other day when the battery charge light came on. Not long after that (the next morning) the car died. I bought a new battery, but when I installed it the charge light stayed on. I have a feeling it's a bad alternator, however I am not sure does anyone have advice. Thanks.
Jun 6, 2006 at 4:15 AM
LOSONE
  • 1,616 POSTS
The easiest way is to the test the voltage across the battery with a meter. Lights on engine running it should read 13.8 to 14.7. If it is below 13V then replace the alternator. I know, take it to the zone and they will do it free. I just don't trust the zone. Too may bad experiences.
Jun 6, 2006 at 5:19 AM
Suggested Repair
With the engine running and lights on, measure voltage at the battery. It should read about 13.8 to 14.7 volts. If it is below 13 volts, replace the alternator.
Conversation Summary
The owner of a 1990 Toyota Celica saw the battery charge light come on, and the car died the next morning. A new battery did not turn the light off, so a bad alternator was suspected. The expert advised checking battery voltage with the engine running and lights on, expecting 13.8 to 14.7 volts, and replacing the alternator if the reading is below 13 volts.
