2003 Toyota Celica ABS Light On
10 GOALS
Hi, I have a 2003 Celica GTS with a ABS dashlight that doesn't go off. A shop said it was the right rear ABS senor. Does anyone know how to troubleshoot/repair this problem? Is it easy enough to DIY it? Thanks!
It requires a special tool-look below for a starting point, the right rear sensor will throw a DTC C0210/33 and C1238/38
[img:16f44bc3d7]http://www.2carpros.com/forum/automotive_pictures/12900_2003_Celica_GTS_1.jpg[/img:16f44bc3d7]
Sep 25, 2007 at 6:29 PM
  • 75,988 POSTS
https://images.2carpros.com/forum/automotive_pictures/12900_2003_Celica_GTS_2.jpg
Sep 25, 2007 at 7:43 PM
BUZZSAW
  • 1,198 POSTS
you can also use a muliti meter, unplug sensore and hook up your multi meter in the two wire holes, put setting on ac voltage, spin wheel if a reading occurs the sensor may be good, wiggle the wire too, do this to each sensor
Sep 26, 2007 at 12:47 PM
10 GOALS
Thanks, will give it a try!
Sep 28, 2007 at 2:49 AM
Suggested Repair
Scan the ABS system for codes; a right-rear wheel-speed sensor fault commonly sets C0210/33 and C1238/38 and may need a capable scan tool. You can also unplug each sensor, set a multimeter to AC voltage, spin the wheel, and wiggle the wiring. A sensor that produces no reading, or a harness that changes the reading when moved, should be repaired or replaced.
Conversation Summary
The owner of a 2003 Toyota Celica GTS has an ABS warning light that stays on. A shop blamed the right-rear ABS sensor, and the owner asked whether it could be diagnosed and repaired at home. Experts said the right-rear sensor can set codes C0210/33 and C1238/38 and that diagnosis may require a special scan tool. They also suggested checking each sensor with a multimeter on AC voltage while spinning the wheel and wiggling the wiring. The owner planned to try that test.
