2001 Toyota Celica Heater Cold at Idle
FNAGY
2001 Toyota Celica GT
84,000 miles
not sure of engine size
My daughter's car has been having heating problem. Sometimes it works and sometimes it doesn't. It will throw out heat while she is moving but when she is idling for any amount of time, it will run cold. We have changed the thermostat and was told that the bottom hose was staying cold. She has never overheated. She hasn't changed her serpentine belt...could this be slipping at times and causing the problem.
Mar 5, 2007 at 2:50 AM
  • 75,988 POSTS
They made it sound that the radiator is clogged-try this remove the Stat and go for a test and see what happens and comeback.
Could be a heater control valve at the heater hose. and again it might be an entirely different issues.
Mar 5, 2007 at 7:05 AM
  • 75,988 POSTS
[quote:24db354cc2="fnagy"]2001 Toyota Celica GT
84,000 miles
My daughter's car has been having heating problem. Sometimes it works and sometimes it doesn't. It will throw out heat while she is moving but when she is idling for any amount of time, it will run cold. We have changed the thermostat and was told that the bottom hose was staying cold. She has never overheated. She hasn't changed her serpentine belt...could this be slipping at times and causing the problem.[/quote:24db354cc2]
Check the heater contol valve-also try this remove the Stat and recheck for heat.
Mar 6, 2007 at 5:02 AM
Suggested Repair
Check the heater control valve on the heater hose. Also remove the thermostat and retest for heat, which can help determine whether restricted radiator or cooling-system flow is causing the cold air at idle.
Conversation Summary
The owner of a 2001 Toyota Celica reports intermittent heat that works while driving but turns cold at idle. The thermostat was already replaced, the lower hose stayed cold, and the engine has not overheated. The expert suggested possible radiator restriction, checking the heater control valve, and retesting heat with the thermostat removed.
