1997 Toyota Celica
170,000 MILES • 4 CYL • 2WD • MANUAL
HOMAYOKI
How do you replace freeze plugs on engine block?
Sep 17, 2009 at 12:16 PM
  • 75,988 POSTS
If you can get to it-drill a pilot hole and use a slidehammer or my punch it and use a large screwdriver to pry it open-Then use JB weld to seal it-and evenly press it in with a socket same size with the freeze plug-NO easy ascess-you must remove additional components out of the way to get at it-
Sep 17, 2009 at 12:23 PM
