I would like to update my engine, what is the better for this old car?
Very much appreciated.
Oct 27, 2016 at 6:17 AM
ALEJANDRO CAPOTE GONZáLEZ
MEMBER
I would like to have a bigger engine. :)
✓Experienced Mechanic
you really are only limited to the original engine your main problem with doing a swap is that the engine loom will not match nor will the ECU, transmission match up will be a problem as well, you are better off re building with performance up grades to get more power.
