Saturday, June 14th, 2008 AT 6:06 PM
I drove the car for about 10 miles, Everything was fine Shut the car off for about 30 minutes went to start the car, I got the starter grinding with the flywheel then finally the motor cranked over but the timing belt is not turning. I understand that the timing belt probably sheered off the teeth of the belt but why did it lock up?
